06-04-2022 19:29
06-04-2022 19:29
I noticed that Versa 2 step-count delay, for example the current steps are 1000 then I walked for like 80 steps, it should be 1080, instead it shows on the tracker has 1030 steps, then after a while (no walk), it shows 1060 then a little while again later it shows 1082. So the step counter incorrect! I restarted many times, did factory reset, still have same problem, kindly solve my problem
06-04-2022 20:05
06-04-2022 20:05
It sounds to me that it is not really incorrect, but just takes a little time for the display to catch up. Or do you mean that it goes to 1082 instead of 1080?
Best Answer06-04-2022 20:18
06-04-2022 20:18
