12-21-2019
14:45
12:59
ManuFitbit
12-21-2019
14:45
12:59
ManuFitbit
I just purchased the fitbit versa 2 the other day and ever since I keep having a message show up on my phone.
Fitbit cannot accurately use your phone's pedometer without a foreground notification. I'm not sure what it means but I'd like it to go away and fix the problem.
07-18-2021 10:50
07-18-2021 10:50
Here is what worked for me: from the Fitbit phone app, click your image on the top of the main fitbit page. Then, look for a device called MobileTrack and unpair it. The continuous notification went away. If you don't want to use your phone at all to track your steps, then unpairing the MobileTrack device will get rid of the notification. You can add it back later if you want to.
12-22-2019
17:23
14:09
12-22-2019
17:23
14:09
Hi @sdelorme25, welcome to the Community Forums!
Thanks for bringing this to my attention. To better assist you with this, can you please send me a picture or a screenshot of the message that was specified in you post? Please refer to this post to know how to attach an image into your post.
I'll be waiting for your reply.
12-22-2019 18:42
01-03-2020 15:14
01-03-2020 15:14
I am experiencing the same problem. What is the answer?
02-26-2020 16:00
02-26-2020 16:00
Do you have an answer yet for this query, as I'm getting the same message? Thanks in advance.
06-26-2020 12:05
06-26-2020 12:05
I have the first Versa and I've been getting this message for awhile. I see there is still no answer!
09-02-2020 05:46
09-02-2020 05:46
Fitbit does not seem to reply or help with anything..I am getting the same message also sleep scores stopped at the same time unless I nap for less than 3 hrs..lol
12-29-2020 21:09
12-29-2020 21:09
I have it too! So annoying...not having any feedback from fitbit is even more annoying...
03-04-2021 05:20
03-04-2021 05:20
Hi, I am getting the same message. What do I need to do?
Thanks,
03-30-2021 05:00
03-30-2021 05:00
Has there been a solution to this post as I am getting the exact same error.
06-12-2021 23:42
06-12-2021 23:42
do you have an answer for this?
my phone has the same notification.
i have restarted my phone and rebooted my fit bit and it still has the same notification.
06-16-2021 00:07
06-16-2021 00:07
Is there a solution yet?? My LG V60 thinQ is doing it too
07-18-2021 10:50
07-18-2021 10:50
01-18-2023 16:11
02-16-2023 18:00
02-16-2023 18:00
Hi @grimjim98 @ScottKaphingst - the most likely correct answer was posted here
05-16-2023 13:53
05-16-2023 13:53
So does this mean we have to lose the ability for the phone to track steps to get rid of this notification?
