06-24-2018
14:52
09:26
AlejandraFitbit
06-24-2018
14:52
09:26
AlejandraFitbit
My Versa screen is frozen on source output screen.
06-24-2018 16:02
06-25-2018 09:27
06-25-2018 09:27
Hey @_Case3, it's great to see new faces around and @SunsetRunner thanks for stopping by.
I would like to know if the instruction provided by our friend worked? Are you still having issues with your Versa being frozen?
Hope to hear from you soon.
10-30-2018
21:25
09:24
JuanJoFitbit
10-30-2018
21:25
09:24
JuanJoFitbit
My Versa is frozen on the watch face. It won't change the time, count steps, track heart rate or anything. tried to reset several times, shutdown and let it sit for 15 minutes but nothing is working. I'm afraid if I factory reset I will loose all the info it's tracked.
Moderator edit: format
11-01-2018 09:27
11-01-2018 09:27
@Kanelso Thank you for joining us in this thread and our Fitbit Community! I'm sorry to hear that your Versa display got frozen. Thank you by the way for troubleshooting this issue before contacting our forums. Due to this, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You should receive an email from them soon.
Let me know if you have any doubts!
11-30-2018 22:46
11-30-2018 22:46
My Versa screen is frozen. The clock reads 9:08 and 52 seconds, but it's 10:32 now. It is unresponsive to pressing any of the buttons. I tried holding the back button for over a minute and nothing happened.
I was cooking dinner, and when I sat down to eat I realized the face was lit up and not turning off.
I tried to sync it with my android app, and the app said tracker not found. I also tried putting it on the charging dock, but that didn't seem to change anything either. Since none of the buttons are responsive, I can't get to where I can reset my Versa.
I've not had it for a whole week yet. I've not subjected it to any extreme environments or done anything while wearing it that I wouldn't normally do wearing my old Flex.
On the back of the watch, where the heart rate monitor is, of the 4 windows - the second from the left has a green light flickering. This is the only thing going on to tell me there is power happening.
12-05-2018 03:55
12-05-2018 03:55
@WendyDey Welcome to our Fitbit Community! I'm sorry to hear that your Versa's display keeps freezing even though you have restarted it. Since the issue persists, I'll send your case to our customer service department and the'll be happy to follow up.
Please keep an eye on your email account.
I'll be around if you have more questions!
12-10-2018 12:32
12-10-2018 12:32
My Fitbit versa is frozen also. I have reset several times but with no luck. It wont track anything and now wont charge either. This is my second Fitbit in around 6 months. My first one wouldn’t keep its charge. I am quite disappointed. Is there anything I can do or is it pointless.
12-11-2018 04:18
12-11-2018 04:18
@LRanton Thank you for participating in our Fitbit Community! Thank you also for taking the time to try the solutions before getting in touch with our Community. I will forward your case to our Customer Service department and they'll be glad to follow up.
Let me know if you need more assistance!
01-19-2019 06:59
01-19-2019 06:59
I know the original post is quite old but I am having ALMOST the same problem. My Versa is frozen EXCEPT for the time itself. Time is keeping up but no heart rate, steps, stairs, etc. - just the icons but no numbers coming up other than the time. The buttons all seem to be working. I've tried resetting several times now with no change. Any ideas?
01-19-2019 13:57
01-19-2019 13:57
01-19-2019 14:36
01-19-2019 14:36
I’m having the exact same problem! The time is working but it seems as though the actual touch screen isn’t working. Will try and factory reset and see if it works.
01-20-2019 20:53
01-20-2019 20:53
01-28-2019 13:52
01-28-2019 13:52
My Versa is frozen on the Fitbit start up screen.
01-28-2019 14:18
01-28-2019 14:18
I finally got mine going again but it took a reset back to the factory settings to get it going again. And the face that I had chosen was no longer an option so had to select another clock face. But it's worked fine for the past two weeks since I made my initial post up above.
02-21-2019 19:28
02-21-2019 19:28
I’m having the same issue. Except the time still works. What did they tell you to do?
02-21-2019 19:29
02-21-2019 19:29
That is happening to me now. What was the advice?
02-21-2019 20:08
02-21-2019 20:08
02-22-2019 04:46 - last edited on 10-25-2019 19:29 by LiliyaFitbit
I got no answers. It finally reset after the battery died. Still seems very
glitchy. Some emails can't be swiped away and stay until I do a restart.
UGGhh
02-22-2019 07:07
02-22-2019 07:07
It was the factory reset that got me going again and haven't had the issue pop up again since.
