09-28-2023
22:51
06:29
09-28-2023
22:51
06:29
My versa 3 has suddenly stopped connecting to GPS. Only had the watch 4 months. Any advice would be much appreciated.
09-29-2023 06:33
09-29-2023 06:33
Hi there, @Stevie.p. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Please note that if you're in a new location farther away from where you normally walk, it may take a few minutes to connect.
With that being said, I'd like to know if you've recently changed your normally location? How long do you wait for the GPS signal to connect? If you've noticed it's less than 5 minutes, please let your watch try to connect for at least 5 minutes before cancelling the exercise. Your Versa 3 will continue to try connecting and you can go about your walk.
Also, please make sure your Versa 3 meets the requirements for connecting to GPS. For more information, see Why isn't GPS working on my Fitbit device?
Moreover, please be advised that environmental factors, including tall buildings, dense forest, steep hills, and thick cloud cover, can interfere with your device’s ability to connect to GPS satellites. If the signal is blocked—either because you're indoors, underground, or due to another reason—GPS won't work.
09-29-2023 06:33
09-29-2023 06:33
