06-07-2020 11:51
06-07-2020 11:51
GPS was working yesterday, today it is not. Worked 3 out of 7 days last week. I would like to resolve this issue soon as possible.
Best Answer06-07-2020 12:02
06-07-2020 12:02
Hi, could you be a bit more specific please? As the Versa range does not have GPS built in it relies on a phone, is your Versa no longer connecting to your phone?
Best Answer06-07-2020 12:42
06-07-2020 12:42
Best Answer06-07-2020 12:50
06-07-2020 12:50
Could you try resetting the Versa from scratch? In the Fitbit App delete the Versa, uninstall the app and make sure there are no Fitbit devices present in your phone's Bluetooth menu. Then reboot the phone and reinstall the app and setup the tracker from the start.
Best Answer06-07-2020 14:53
06-07-2020 14:53
Best Answer06-08-2020 06:58
06-08-2020 06:58
May I ask what model is your phone @Cheryl224 ?
Does GPS hook up while the Fitbit app is open on the phone, but wont if the app is not open?
Best Answer06-08-2020 08:08
06-08-2020 08:08
Best Answer06-08-2020 08:10
06-08-2020 08:10
Samsung S9+. Today GPS is working
