Hi, the iPhone is known to cause issues with this, but what you can try is this:
1. Go to the notifications
2. Scroll down to quick replies, press it.
3. you should see there the apps you enabled to show notifications, in your case tekst messages.
4. Press the tekst messages and you will get a screen with "standard" quick replies.
5. On top of this screen, you'll see as a standard answer "yes".
6. Press that and insert the answer you really want as a quick reply and you're done.
Do not guarantee that this will work with an iPhone.
Welcome to the forums!
You cant until Iphone does something about it. Its a Iphone problem not a fitbit problem.
See this thread by @MarreFitbit
Hope to see you around!
Wendy | CA | Moto G6 Android
