09-14-2022 07:25
09-14-2022 07:25
PLEASE HELP!! I've spent hours researching online and reading these help forums but still confused. I am 60 years old - resting heart rate is 62 or so daily. My Heart Rate Variability varies between 12ms and 15ms daily - week after week - month after month. There is NO explanation if this is normal or not so I researched and everyone says a reading this low means I'm either dead or dying and bad things are happening to be this low!! That's scary to read.....I am fit - in shape (5'11" - 180lbs) - play sports several times a week (Pickleball / Volleyball /Swim/walk/bike) and more but worry now that something else is happening inside I don't know about. Blood work very good....
09-14-2022 07:43
09-14-2022 07:43
You are apparently still as healthy as when you posted same thing ten days ago. My non-professional, non-medical suggestion: don't worry about actual numbers but maybe look at trends; different places might measure this differently or have different definitions of it. If you notice any big change in trend over time, consider that one piece of information along with all the other data you have. If still concerned, mention it to your doctor.
Best Answer09-14-2022 08:00
09-14-2022 08:00
Best Answer11-14-2022 05:04
11-14-2022 05:04
A couple of things in response:
I hope this is helpful.
Best Answer11-14-2022 08:13
11-14-2022 08:13
THANK you for your reply! I'll assume something isn't right with my Fitbit because when I researched it for way too many hours - every article said my numbers mean I'm in bad health yet I'm very active - decent blood work - regular checks up and more. Since I first posted my question my HRV hasn't fluctuated at all. It's a straight line of about 10 or 11 which again - according to research - isn't possible. I was actually in a panic over this thinking something wring was going on inside me even though I feel fine. Jim
Best Answer11-14-2022 08:14
11-14-2022 08:14
03-19-2023 19:32
03-19-2023 19:32
There are many discussions in other chains about rampant inaccuracies in Fitbit's HRV data. I just started receiving FB HRV data showing my HRV at 15, which seems quite low and I'm relatively fit with a RHR of 60. This made me both anxious and even more, curious. After some online research and reading the other Fitbit community chats, I discovered an app called "Elite HRV", which you can freely download. It utilizes a polar HR strap to measure your HRV, sync-ed via bluetooth, and I got a reading of 52 on the first try. There seems to be a view that a chest strap provides more accurate HRV information vs a wrist-based monitor, but I don't know if that's true.
More importantly, the Elite HRV site has numerous articles with useful background on HRV. One of them has this table below, which indicates that there are multiple HRV software programs that use different metrics to report user HRV (their app metric is the 3rd column). I don't understand why there are so many different metrics for measuring the same thing. It's also not clear to me what metric Fitbit is using to report HRV and how it compares to these other metrics.
I just started using Elite HRV but you could try that to see if it is useful for you.
03-20-2023 15:21
03-20-2023 15:21
