06-26-2020 07:07
06-26-2020 07:07
I have spent hours of my fitness journey poring over forums, manuals, reddit etc and I have not found any solution which works for the Versa Lite. Has anyone successfully achieved this or do I take it as an unachievable goal like the 2h marathon.
oh wait...
Best Answer06-26-2020 07:14
06-26-2020 07:14
Hi, @Rabid_Raptor , I have solved this message twice simply by ignoring it. I had a problem with my Versa, did a factory reset and got that message. Obviously no way to sync. However I decided to just go ahead and try to set it up again anyway, ignoring that message. I just clicked on my account icon (that’s the picture icon top left on the front screen), scrolled down to + set up a device and went from there.
I can’t remember why I did the factory reset the second time... I think it was to help someone in the Community. I assumed the previous glitch was just that, but no, I got the same dreaded red X again. So the second time I just ignored it and set it up.
Have you tried that?
06-26-2020 07:28
06-26-2020 07:28
Thx - I tried it at least 10 times - but if it worked for you I will give it another shot. I think there is a timing window when the watch is booting up and gets detected by the phone and shows the 4 digit code.
Your reply has given me hope!
Thanks!
07:56
05:48
06-26-2020
07:56
05:48
@Rabid_Raptor , also worth logging out of yiur app and logging back in again before trying. Sometimes shutting down the phone/ tablet altogether also helps.
Sorry you are having this issue. Let us know how it goes!
Best Answer06-26-2020 20:45
06-26-2020 20:45
Thanks Julia. Got it to work. Appreciate your help.
I put together my experience -
