05-29-2019
14:57
07:03
MarcoGFitbit
05-29-2019
14:57
07:03
MarcoGFitbit
My Versa HR sensor stopped yesterday. I have tried restarting, resetting to default settings, and changing clock face back to a Fitbit clock -- all several times with no luck. Now my left button is periodically not functioning and my Versa screen is randomly opening certain apps that I cannot get out of without shutting down. Please help!
Hello @NHolmes thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for sharing your experience with us. I would also like to thank you for letting us know the troubleshooting steps you've tried so far.
At this moment, I would like to suggest you to perform a factory reset on your Fitbit Versa. Note that a factory reset will remove apps, stored data, personal information, credit and debit cards (for Fitbit Pay-enabled devices), and saved settings, so please sync your Versa before proceeding.
To factory reset your device:
On your device, open the Settings app > About > Factory Reset or Clear User Data.
After the factory reset you will need to set up your Versa as a new device:
Thanks for your patience and understanding, give this a try and let us know the outcome.
Best Answer@MarcoGFitbit I have performed the factory reset a few times since Tuesday. I am finally getting some heart rate sensor readings but only sporadically. My alarm app is still opening by itself and my left button won't work to close it. I had downloaded the Air Index app a few days ago. I removed it after I started having problems. Could the app have caused a problem?
Best AnswerMy Versa has now completely stopped working and is cycling on and off repetitively by itself. Tried manually restarting with no luck. Tried charging, no luck. It's less than a year old with minimal wear. Starting to regret this purchase.
