01-08-2021
23:15
17:24
RicardoFitbit
01-08-2021
23:15
17:24
RicardoFitbit
Hey just got a new versa 2 and I’m worried it’s goin to use all my data how do I stop this please!!! And only use wifi help
01-08-2021 23:50
01-08-2021 23:50
Hi, it will only use wifi when its on the charger.
The rest of the time it only syncs with the phone via Bluetooth.
So its how you setup the phone that matters. You can check your Fitbit app data usage to see how much it is, probably minimal.
If your phone is on wifi then the Fitbit app/watch uses no Data at all.
Hope this helps.
Best Answer01-08-2021 23:50
01-08-2021 23:50
Hope this helps.
