05-25-2018
20:16
04:39
AlejandraFitbit
05-25-2018
20:16
04:39
AlejandraFitbit
I’ve got my Versa less than 3 weeks ago. It’s working fine but the screen is broken 2 days ago by accident that caused injury as well. I called the Fitbit support and they told me the warranty doesn't cover damage caused by accidents, which totally understandable. But there is no repair store or anywhere I could replace the screen. It’s ridiculous!
Now how can I repair my watch? There should be a process for this kind of situation. What can I do now?
11-13-2019 11:28
11-13-2019 11:28
11-25-2019 10:49
11-25-2019 10:49
Joesge seems to able to repair all the Fitbits. You can google Joesge repairs to see all their prices. Let me know if this helps 🙂
Best Answer11-25-2019 10:52
11-25-2019 10:52
Sometimes the screen protectors don't help but if it does break there are always companies that can fix these for you. Joesge does online repairs.
Best Answer11-26-2019 01:00
11-26-2019 01:00
Contact info please
Best Answer11-26-2019 01:06
11-26-2019 01:06
Joesge charges $110 hell you might as well buy a whole new watch 🤦🏾 r u kidding me!
Best Answer11-26-2019 06:46 - last edited on 08-26-2020 19:09 by LiliyaFitbit
It is 100 at the moment. If you need their help you can send your device
in.
Thank you,
Joe P
Best Answer11-26-2019 08:29
11-26-2019 08:29
11-26-2019 08:33 - last edited on 08-26-2020 19:09 by LiliyaFitbit
Anytime.
Thank you,
Joe P
Best Answer12-27-2019 15:36
12-27-2019 15:36
i didnt drop my watch i didnt use it and the screen is stuck at the top of the screen
Best Answer02-10-2020 06:27
02-10-2020 06:27
This is a similar issue my son was at the gym and the strap came away from the screen part and the watch fell and the screen cracked .
I would like to know where we can fix it as it is not covered under warranty .
Poor responses from Fitbit.
no repair centre.
So how do we fix our broken watches which are still under warranty ..
V
Best Answer02-10-2020 06:50
02-10-2020 06:50
Best Answer02-10-2020 06:54
02-10-2020 06:54
Best Answer02-10-2020 07:56
02-10-2020 07:56
I agree. I’ve been working w them Patiently for a week now bc my back button won’t work.so my scream is stuck on last app I went to. I got my husband a itouch smart watch and he loves it. Has had no problem. And it was way cheaper then the Fitbit.
Best Answer02-10-2020 14:16
02-10-2020 14:16
Best Answer02-20-2020 17:27
02-20-2020 17:27
the repair site you mentioned quotes me a cost of $125 to repair the screen. The device when I bought it brand new 9 months ago was $160. Disappointing, but wanted to make sure people knew what to expect.
Best Answer02-20-2020 17:49 - last edited on 08-26-2020 19:10 by LiliyaFitbit
Price I see is $90.
Thanks,
Joe P
Best Answer03-03-2020 11:15
03-03-2020 11:15
So you mean to tell me I'm spending hundreds of dollars on a watch and a cracked from the inside screen cant be replaced? I dropped it one time after owning it 3 month not even. So, disappointed.
Best Answer03-08-2020 05:27
03-08-2020 05:27
Same thing happened to me! Does Fitbit support their products?
Best Answer03-08-2020 05:37
03-08-2020 05:37
I went to Target. They said they do not do repairs. 😞
03-08-2020 09:13
03-08-2020 09:13
They have replaced my versa at least 5 times. I've lost count. I'm definitely looking into another brand
