05-02-2018
09:24
09:14
AlejandraFitbit
05-02-2018
09:24
09:14
AlejandraFitbit
How do I factory reset my Versa? Wipe it off.
12-31-2018 08:13
12-31-2018 08:13
Hello everyone, I hope you're doing well. It's nice to see you around @Odyssey13, thanks for all your help.
I appreciate your participation in the Forums and for sharing your experience with us. If you have already tried the instructions provided by @Odyssey13 to perform a factory reset on your Versa and are still having issues with it, please let us know so we can help you further.
Thanks for your patience and understanding, have a great day.
01-01-2019 09:42
01-01-2019 09:42
Ive turned of my fitbit versa to factory settings and now it wont turn on
01-02-2019 07:22
01-02-2019 07:22
Hello @Bridgebrattan, thanks for joining the conversation, it's nice to see you around.
I appreciate you have come back after performing a factory reset on your Versa. Now, if it's not turning on, plug it in and leave it charging for 30 minutes, after that try to restart it by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen. If this doesn't seem to work try a different USB port and try again.
I hope this can be helpful, give it a try and let us know the outcome.
01-06-2019 22:32
01-06-2019 22:32
I am having the same issue. Called Fitbit and they told me to try to delete the device from my phone and reconnect it. Worst advice ever! It’s now locked and not connected.
01-07-2019 00:01 - edited 01-07-2019 00:02
@AmmyyyElizabeth what do you mean by locked? And could you please elaborate on steps you performed? Also, what's your phone model and OS.
01-07-2019 00:50
01-07-2019 00:50
mine has done the same thing. Locked completely off my Fitbit and I now can’t sync it to my phone because it will not let me see the pin to connect.
01-07-2019 00:51
01-07-2019 00:55
01-07-2019 00:55
@Shannin this message means you typed the wrong pin at least 10 times. If you open Fitbit mobile app, when was the last sync? Is versa still linked with your Fitbit account or did you remove it from Fitbit mobile app? What's your phone model and OS?
01-08-2019 09:15
01-08-2019 09:15
01-08-2019 09:23
01-08-2019 09:23
01-08-2019 20:46
01-08-2019 20:46
01-09-2019 02:39
01-09-2019 02:39
@Mamoune69 Great news! 👍🏻👍🏻👍🏻
01-16-2019 23:35
01-16-2019 23:35
My versa is telling i need to unlock with phone, but im strugling to connect
01-17-2019 13:45
01-17-2019 18:24
01-17-2019 18:24
01-19-2019 09:42
01-19-2019 09:42
Factory reset solved.
1. Get the charger without the watch in it.
2. Mark the places where the watch buttons would be.
3. Use an unfolded paperclip heated up with a lighter and poke holes with the hot wire at the location where the buttons will be at when it's charging! Remember do not leave the watch in the charger while doing this!
4. After poking three holes (one for each button, two on the right one on the left) Put your watching on the charger.
5. Use three unfolded paper clips and with the help of a few friends insert one in each of the holes.
6. Start the process of factory reset. Which is described above . Bingo done and working
01-19-2019 09:45
01-19-2019 09:45
Bingo done and working.
01-19-2019 09:56
01-19-2019 09:56
Factory reset solved. If you can't do it through the app. The charger furnished with the watch does not allow you to hold the three buttons for it covers them. So instructions are only for those that can understand and do it at your own risk!
6. Start the process of factory reset. Which is described below.
Factory reset
01. Connect the Fitbit Versa to the charging cable.
02. Hold all 3 buttons for about 15 seconds, until the Fitbit logo appears.
03. When the Fitbit logo disappears release the Bottom Right button, then keep holding the Left and Top Right button until you feel a strong vibration.
Bingo done and working. 😊
01-22-2019 13:49
01-22-2019 13:49
I did a factory reset on my Versa and now it's only showing the Fitbit logo with download app in different languages. What do I do now to get my watch working again? How long does it take for a reset?
01-22-2019 19:47
01-22-2019 19:47
@MarieAtanasov Well, it's displaying a setup screen, so it has already reset itself. Go to your phone's Bluetooth settings and remove (forget) Versa from the Paired Devices list, then reboot your phone. Place Versa in the charging dock near your router and open Fitbit mobile app. Tap on the Account icon (looks like a business card) in the top right corner and scroll down to Set Up a Device. Choose Versa. It will ask you to replace the current one. Confirm. Follow the instructions on the screen.
