I have a Fitbit Charge 3 and just won a Fitbit Versa. I just learned that they both can not be on the same account. I have a android phone and want to have two Fitbit apps on my phone is that possible? I dont want to put the Versa on my Ipad as I dont have it with me all of the time.
Unfortunately you cannot have them both on the same account, even on different sync devices, i.e. phone and iPad.
To put one on phone and one on iPad, or even both on phone, you would need a separate account for each, but then could not combine the data.
The only way you could use both is to sync the one you are using, then add the other tracker to your account while dropping the first - perhaps more trouble than it's worth, unless switching only infrequently.
This used to be possible but not with the latest models that use the App Gallery.
See Can I use more than one Fitbit device with the same account?
"Note that you can't connect multiple devices that use the Fitbit App Gallery to one account. For Fitbit Charge 3, Fitbit Ionic, Fitbit Inspire series, and Fitbit Versa series, only connect one of these devices to your account at a time."
