12-27-2021
10:42
14:47
12-27-2021
10:42
14:47
This workout should be a quick add and why can’t I sync my heart rate to machine? Entering manually works but would be nice if it’s syncs up. Thank you
Hi there, @BobbyB650. Welcome to the Community Forums. We‘re taking your comments and sentiments in regards to our products into consideration.
Please note that when a specific exercise is not available within the exercises we offer (such as Rowing), we suggest to use "Workout". Once you finish the activity, you can rename the activity to "Rowing Machine". Note that the information to enter will change depending on the nature of the exercise. To give you an example, if you change from "Workout" to "Run", it won't remove the calories but will add distance as the main stat to be displayed, this happen depending of the activity you are categorizing. However, your the data already tracked will be still counted for your daily totals.
For more information about how to do so, see How do I add, edit, or delete Fitbit data and activities?
