12-14-2018
07:04
18:23
EdsonFitbit
12-14-2018
07:04
18:23
EdsonFitbit
We have misplaced our versa and have tried the bluetooth apps the boards have suggested. WE are able to sync it, any other suggestions?
Thank you
Moderator edit: added label
12-14-2018 11:24 - edited 12-15-2018 14:30
The tracker is nearby. I use this app https://findmyfitbit.com
The trial will tell you if it can see your tracker, then pay to do the search. They will refund if the app if it fails to find.
Other than that, wait until it is dark,and send a test notification.
It might be possible to set an alarm through the web site, in any case you want to see if you can hear the vibration.
12-14-2018 11:25
12-14-2018 11:25
Welcome to the forums!
Is the Bluetooth finder even coming close? When Mine did I search the area it came close to and found it in my closet. It actually fell in a shoe.
But it has to be close if its syncing.
Hope you find it!
Wendy | CA | Moto G6 Android
