How to remove apps from my Versa 2?
I literally just got this in the mail today..getting used to it..there are some apps on my Fitbit that dont relate to me..how do I remove them? Or do they stay on there.
6 REPLIES 6
The apps that come pre-installed just stay there and don't do any harm.  You can re-arrange the order by hold and drag.  Other ones  that you add, you can also remove.
Add or remove apps from phone
Profile Pic > Versa 2 > Apps
Thanks so much for the help.. I will have to deal with the apps. I
definitely dont need deezer, starbucks, spotify , music, one of the main
reasons I purchased this..was for my sleeping pattern where do I find that?
Thanks
Melissa Coutu
Hi @Daisyduke05, welcome to our Fitbit Community! Regarding your question about how to remove apps that don't relate to you on your Versa 2, I'd like you to check out this help article, under the subject "How do I remove apps from my Fitbit watch?" and follow the steps.
Thank you so much for your help @JohnnyRow.
I'll be around if any question arises.
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
@Daisyduke05   When I see the apps you mentioned, I realize I was wrong.  Some of those can be removed according to the instructions given by @JuanJoFitbit .  There are a few original ones that cannot be removed, but some can be.
Sleep should be a tile on main 'Today' page of phone app.
His method of moving apps does not work. There is no hold where icon enlarges.
Do you have another method please?
I don't see anything like that in his instructions reference.
