08-12-2020
01:24
18:38
RicardoFitbit
08-12-2020
01:24
18:38
RicardoFitbit
A little while ago, my Versa was having trouble syncing, so the watch time was off. For whatever reason, that happens every once in a while, and usually, I just restart my watch and it fixes itself. This time, that didn't work, so I thought I would try a factory reset, to see if that would work. So I charged it and went to set it up again on the Windows app (the app on my phone doesn't work for some reason, but that's another story), and it won't finish set up. It gets to the point where the green checkmark shows up, and then a white version of the Fitbit logo, and there it gets stuck. It does not change screens. Eventually, it goes to sleep, and when you wake it up, it shows the "To start, download the Fitbit app" screen. I am getting really annoyed that it won't finish the setup, especially because the app says it's syncing, and the watch responds to the setup, but not all the way. I have tried restarting it and factory resetting it again, but nothing has worked. Please help me, I want to be able to use my watch again!
08-12-2020
18:29
11:01
08-12-2020
18:29
11:01
Hi @rbmaw, welcome to the Community Forums.
First, I'd like to appreciate your effort and patience troubleshooting this situation prior to posting. If you haven't already done so, I recommend you to check all the information that's specified on: How do I set up my Fitbit device? to check if all the requirements are correctly configured to setup your device. Then, you can move forward and try the troubleshooting steps that are specified on: Why can't I set up my Fitbit device? and let me know how it goes.
Let me know if the issue persists and if you have any additional questions.
