09-15-2019
20:27
10:30
JuanJoFitbit
09-15-2019
20:27
10:30
JuanJoFitbit
Can't find any instructions to reset the time.
09-15-2019 22:10
09-15-2019 22:10
Fitbit trackers get time and date from phone or other sync device each time they sync. Other than time zones issues when off by exact number of hours, that is the only way to set time.
09-18-2019 10:30
09-18-2019 10:30
@Grumpi welcome to our Fitbit Community! By the way, I'm sorry for the late response. However, I would like to follow up and would like to know if your Versa is still showing the wrong time or if it could be reset after following the advice that shared my friend @JohnnyRow since that is the way to correct the time on your Fitbit device.
If you found his post helpful, please accept it as a solution so other users that have the same inquiry can find it easier.
Looking forward to your response! 😀
