05-08-2019 09:59
05-08-2019 09:59
I recently just finished a clockface that i wanted to send to a friend.
I know how to connect my versa and download it directly but is there a way to send the build to a friend so they can set it on their versa?
Or would it need to be published and put on the clockface download on fitbit itself?
05-09-2019 09:52 - edited 05-09-2019 10:08
Hi, do you also want to publish your CF in the Fitbit Gallery and is it a free CF? If yes, the CF gets a name, something like this:
https://gam.fitbit.com/gallery/clock/xxxxxxxxxxxxx. The xxx's stand for the specific number of your CF. You can then send the link of your CF to your friensd(s). Your friend needs to open that link in the browser of his/her phone, otherwise it will not work. The link I posted as an example, I got also from a friend, who I helped developing it, and this way I could download this particular CF directly after being approved by Fitbit to publish it in their gallery.
Best Answer05-09-2019 09:52 - edited 05-09-2019 10:08
