05-25-2020 23:16
05-25-2020 23:16
Just got a Versa 2. The clock face only shows the time, but it doesn't say whether it's "am" or "pm." Is there an option for this somewhere on the device or the app?
05-26-2020 07:58
05-26-2020 07:58
That would be a function of the individual clock face. There are many you can choose from. Just look at choices for one you like that shows AM/PM.
Best Answer02-16-2022 02:02
02-16-2022 02:02
I have this problem on Charge 5. Not a single one of the 23 click faces shows AM/PM
Best Answer02-16-2022 05:56
02-16-2022 05:56
Hi @SunsetRunner - the display depends on your profile clock settings, if you select 24hr mode it won't show AM/PM and it's also possible that the clock face in question doesn't support correctly 12hr mode, as mentioned by @JohnnyRow .
So first check you have set it right, you can log into your settings here
And remember to hit Submit at the bottom and then sync the watch after making changes.
Best Answer02-16-2022 14:29
02-16-2022 14:29
Thanks your your reply. My fitbit is already set to 12 hour. The issue is that I can't find a single clock face that supports 12 hour mode correctly. I went through all of them.
02-16-2022 19:49
02-16-2022 19:56
02-16-2022 19:56
I realize I posted this on the wrong forum. I have a Charge 5. SimpleClockPro is not one of the options.
Best Answer02-16-2022 20:10 - edited 02-16-2022 20:11
@piilstil yes wrong forum, But are you sure you went to your profile to set the hour format, you can log into your Profile Settings and did you sync your watch afterwards?
