01-23-2019
03:00
06:02
JuanJoFitbit
01-23-2019
03:00
06:02
JuanJoFitbit
How do I uninstall a clock face and where do I access developer menu?
06-12-2020 10:38
06-12-2020 10:38
did you solve it?
06-16-2020 04:49
06-16-2020 04:49
After trying "all of the above," I again just gave up and quit trying. Then one day, several weeks/months later when I decided to change my clock face again, I looked and the unwanted clock face was gone. The bottom line is, yes, my problem is gone, but I have no idea what finally took care of it.
06-16-2020 05:06
06-16-2020 05:06
08-07-2020 06:13
08-07-2020 06:13
Delete I dont how to can you help me
08-07-2020 10:22
08-07-2020 10:22
Hello there, to remove a clock face change the clock face to the one you want. From there, you can click on the unwanted clock face on the “My Clock Faces” page and press “Remove clock face”. They key is to not have the clock face you are trying to delete selected on your Versa.
08-07-2020 13:05 - edited 08-07-2020 13:05
How do you get my face clocks page
08-07-2020 15:36
08-07-2020 15:36
Click on the app, press your account icon, press “Versa”, and then press “Clock Faces”.
11-21-2020
11:45
06:09
JuanJoFitbit
11-21-2020
11:45
06:09
JuanJoFitbit
I've found that not to be true for mine- I "unsaved" the unwanted clock face in the App (in "details" for this particular Clock Face there is no Remove, Delete or Uninstall). After three Syncs, it hasn't been removed from the watch. }: (
But you're "allowed" only five. If it's taking up a space, there's a face you can't install that you DO like. Or will it delete one you want to keep when you want to add one that suits you better?
What if that particular Clock Face has NO remove option on its Clock Face Page in the App?
I have two like that, that I cannot remove.
Moderator edit: merged reply
11-22-2020 08:01
11-22-2020 08:01
Hello, do you have the two faces selected (using it)? If so, set another face and then the remove option should be available.
11-22-2020 12:19
11-22-2020 12:19
11-22-2020 14:22
11-22-2020 14:22
I completely understand! So, I had trouble with this too. Can you please re-save the unwanted watch face and re-select it to be on the watch? Make sure the unwanted face is showing up in the watch. Then, select a different face and make sure it shows on the watch. After that, click on the unwanted watch face and see if it has the remove watch face available. This is kinda jimmy rigging it, I’m not sure if it will work. Hope it does!
08-04-2021
15:43
06:08
JuanJoFitbit
08-04-2021
15:43
06:08
JuanJoFitbit
I had to go to setting-customize-digital on watch to get original clock face back.
setting-always on-customize-digital or analog on watch.
08-16-2021 02:20
08-16-2021 02:20
In current app version I cannot see my clock faces.
Account Icon > Versa 3 > Clock Faces just takes me to the general clocks and apps gallery for downloads. It doesn't actually show which clocks I've downloaded.
Can anyone show the clear path to access our current downloaded clock faces on the app?? Pretty please??
09-08-2021 04:45
09-08-2021 04:45
I had the same problem and find the solution by luck.
When you go to clock faces, at the top you see 3 tabs. Versa 3, Clocks and App.
Simply tap on the Versa 3 tab and you'll see your clocks and delete them from there.
09-09-2021 14:03
09-09-2021 14:03
Hello everyone. For all of you who are new to the Fitbit community, welcome.
Thanks to all for the efforts to resolve the issue, sharing the solutions and steps you've tried. I understand how you are feeling, your feedback and comments are greatly appreciated. You can find information about changing or uninstalling clock faces in How do I change the clock face on my Fitbit device?
I'll be closing this thread from further comments. If you have more questions, please reach out to our Support team or open a new thread.
See you around.
