04-11-2019 06:14
04-11-2019 06:14
Hello everyone!
I am about to buy me the new Huawei P30 phone, not the PRO version neither the LITE version. Just P30. Would it sync with my fitbit Versa? Now I have iPhone 6s and it works just fine, but for several reasons I am thinking about changing the device and I have noticed there are some problems with Huawei Lite phones, but will it work with Huawei P30? How can I check the compatibility?
Thanks in advance for any help.
04-11-2019 07:30
04-11-2019 07:30
Hi, you can check this on two sites:
1. www.fitbit.com/devices. It will show you a site with a search bar, type in Huawei and see if your future device is in the list.
2. https://help.fitbit.com/articles/en_US/Help_article/2315/?q=compatible&l=en_US&fs=Search&pn=1. Scroll down the page untill you see "Android Devices", click it and scroll down to Huawei. Good luck!!
07-11-2019 14:32
07-11-2019 14:32
Just wondering how you got on? Was the P30 Lite compatible with your Fitbit?
Best Answer07-15-2019 23:30
07-15-2019 23:30
Hi, I usually received a pop-up notification on my phone (P30) that my Charged HR cannot connect on my phone because my PIN/Password is in correct. I tried to removed and paired it again and got the same pop-up message. But, after I made a test call, it vibrated though a bit delayed (about 10-15 secs) than the usual (5-10secs).
Best Answer07-25-2019 04:10
07-25-2019 04:10
Hello, I have P30 and Versa too. After first pairing i did not received any notification and also sync was very poor. Then i have followed this instruction for P20 lite:
https://help.fitbit.com/articles/en_US/Help_article/2322#huawei
and from that time I have no problem with notification, sync is not perfect (i must repat sync), but it can be survived.
But, notifications and syns fails, when i am trying to connect versa with another device (computer). Then i must turn off bluetooth on other device, restart P30 and it is working again.
Best Answer11-07-2019 14:56
11-07-2019 14:56
i am thinking of getting a versa and i currently have a p30 any luck on if the p30 works with the versa?
Best Answer11-07-2019 15:00
11-07-2019 15:00
11-07-2019 15:02
11-07-2019 15:02
thanks for the reply, mine is just the p30 tho and online it only says p30 pro and p30 lite. so.im abit confused what to do.
