07-23-2020
08:21
12:08
DavideFitbit
07-23-2020
08:21
12:08
DavideFitbit
My Fitbit Versa is broken. I want to use MobileTrack, I clicked on set up device but MobileTeack is not listed, so now what do I do?
07-23-2020 11:30 - edited 07-23-2020 11:34
Hello @MeMeT53 and welcome to the Help forums. Not every phone supports MobileTrack. There are many, many Android phones that don't support it. Sorry.
There used to be a link where you could check if your phone model supported MobileTrack. Fitbit recently updated many of the Help pages and that link doesn't seem to exist any more.
Laurie | Maryland
Best Answer07-23-2020 12:47
07-23-2020 12:47
@MeMeT53 Click on the exercise tile. Top right, there is a timer icon. Click on that and mobile track should come up. Set up device has nothing to do with mobile track.
Best Answer07-23-2020 19:01
07-23-2020 19:01
Best Answer07-23-2020 19:13
07-23-2020 19:13
You already had the fitbit app for the Versa, right? You just go on the Fitbit app and into the exercise tile, and click the timer with + icon. No tricks needed. It's designed in case you forgot your tracker or whatever.
Pretty sure if it was available on my old S5, it'll work on a note 10.
Best Answer07-23-2020 19:17
07-23-2020 19:17
Best Answer07-24-2020 04:19
07-24-2020 04:19
@MarkMM wrote:You already had the fitbit app for the Versa, right? You just go on the Fitbit app and into the exercise tile, and click the timer with + icon. No tricks needed. It's designed in case you forgot your tracker or whatever.
The feature you are describing is MobileRun. MobileRun is a way to get a GPS map of your walk/run/hike if your Fitbit doesn't have connected or built-in GPS. MobileTrack lets your phone be your Fitbit in your pocket all day long. If a phone supports MobileTrack, that choice is at the very bottom of the + Set Up a Device screen.
It is very easy to confuse the two.
Laurie | Maryland
Best Answer07-24-2020 07:34
07-24-2020 07:34
Ah. Sorry for getting involved. lol. I wasn't aware there was another one.
I did however, read that mobile track won't show in the add list if you already have a tracker on your account. There seemed to have been mixed results with that. Could be worth a try removing the no longer working Versa? Or Maybe @MeMeT53 already tried that.
Best Answer07-24-2020 08:49
07-24-2020 08:49
