I've looked all over the place and even used several tracking apps such as the bluetooth locator and Bit-finder with no success. I know it's in one room and have torn the room up looking for it, but no dice. Is there anyway to make the fitbit vibrate in order to hear it by using my phone? I'm worried cause it's almost dead and I just can't seem to find it.
Hi @Sero Can you sync with it? If is it nearby and still has powernit should sync with your phone. If you have reminders to move on it should vibrate at 10 minutes to the hour. If you have notifications turnednon, get someone to send you a text. Other than those things I cant think of anything. Good luck finding it
Helen | Western Australia
