05-08-2024 07:11
05-08-2024 07:11
When I run on a treadmill the Versa 3 distance tracked makes no sense and is a lot different to the treadmill - for instance today I did 5261 steps, my stride length is 27.2"; multiplying No steps x stride length then dividing by 63,330 (inches/mile) I should have run 2.258 miles, instead my exercise tracked 2.03 miles. The treadmill tracked me as running 3.5km which is is about 2.19 miles. I appreciate the distance won't be 100% accurate on the Versa, but surely it calculates No of Steps x stride length to arrive at a distance travelled (when not using GPS)? This clearly isn't working correctly
05-08-2024 09:58
05-08-2024 09:58
Hello @Grebe68 and welcome to the Community. This explanation is from a moderator. The Treadmill shortcut uses your walking stride length. To get your running stride length, use the Run shortcut with GPS off.
I think this will get you a little closer, but it will never be perfect. Changing speeds and inclines will also add data errors.
Laurie | Maryland
