06-25-2019 05:45
06-25-2019 05:45
Just this week, my Fitbit Versa has been counting my calories burned incorrectly. I've seen other answers to similar posts, but they do not answer my question. I realize that my Fitbit burns calories while resting and sleeping. However, at the end of a day, whereas my normal calorie burn is 1500 to 1800 on average, it's now showing over 8,000 calories burned.
By the way, the steps taken are still accurate.
Any solutions?
06-25-2019 06:34
06-25-2019 06:34
Weight and heart rate are 2 big factors in calorie burn calculation.
Take a look at your heart rate chart to see if it was extra high most of the day. That wouldn't explain it but could be a clue.
Also check you weight did not accidentally get changed to something much too high.
06-25-2019 06:34
06-25-2019 06:34
06-25-2019 08:16
06-25-2019 08:16
Thanks so much for the solution. I had accidentally recorded my weight as 1,418 pounds!! Once I logged in the correct weight, the calories burned went back to normal. Such an easy solution. Thank you again.
06-25-2019 16:40
06-25-2019 16:40
