03-06-2024
18:50
13:02
ManuFitbit
03-06-2024
18:50
13:02
ManuFitbit
My Fitbit changed the time to something that isn’t the right time. How do I change it to the right time?
Moderator edit: clarified subject.
03-06-2024 19:22
03-06-2024 19:22
Hi @lschug2010 - first step is to get the watch syncing fully to get the time set correctly.
This may require restarting the watch, logging out of the Fitbit App and restarting the phone.
If you can get it syncing but time doesn't update, try in the Fitbit App, App settings turning off automatic time zone and sync then turn on and sync.
If this fails, change to another time zone and sync and then change back and sync.
03-07-2024 13:09
03-07-2024 13:09
Hi @lschug2010. Welcome to the community forums.
Thank you for taking the time to share the inquiry regarding time on your smartwatch.
Beside the tips provided by @Guy_, I'd suggest you see the steps listed in the article: How do I change the time on my Fitbit device?
Thanks for the appropriate information provided @Guy_ .
