03-07-2024
00:40
10:55
ManuFitbit
03-07-2024
00:40
10:55
ManuFitbit
So my sleep tracking is a disaster. It says I sleep for 2 hours, or 3 hours, or other ridiculous amounts. How do I fix it? I also use the sleep for android app, and it tracks my sleep accurately through the smartwatch
Versa 3 sleep tracking is not correct
03-07-2024 10:54
03-07-2024 10:54
Welcome to the forums @Trivi4.
Thank you for sharing the inquiry regarding sleep with your Versa 3.
There are some factors that could affect the reading of sleep on your device. Please, take a look at the following:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The Versa 3 may need some days to collect some information (particularly regarding heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same problem.In case the problem is related to the Fitbit app, please try the following as well:
