02-04-2024
14:24
06:27
02-04-2024
14:24
06:27
Had a Versa 2 with original charging cradle. I tried to have the glass repaired when by accidently breaking screen. I had difficulty finding someone to fix it but eventually a shop said he would but he ended up supplying with a working 2nd hand Versa model which was working OK until it needed charging. It doesn't seem to charge in my original Versa 2 cradle. Does anyone know if I need to buy a separate Versa charger or should my Versa 2 charger work with this older model?
02-04-2024 14:53
02-04-2024 14:53
If you are asking original Versa and Versa 2, different chargers. Go to Amazon for 3rd party charger for Versa, likely now called Versa 1, I believe same charger as Vera Lite.
02-04-2024 14:53
02-04-2024 14:53
02-05-2024 02:05
02-05-2024 02:05
Cheers Johnny Row, that's exactly the answer I needed.
