11-29-2020 18:35
11-29-2020 18:35
I do have quick view turned on, but while tossing and turning the Versa keeps turning on at night when I'm trying to sleep and it probably is a drain on the battery as well. I really like having quick view when I'm awake during daylight hours but it's pretty annoying to have to go back in and toggle the setting on and off every single day.
Is there a way to set the Versa screen to not turn on automatically between certain hours or something similar? Like a way to put the display to sleep.
11-30-2020 01:38
11-30-2020 01:38
Update to finding this setting, I still cannot find it in the app but I found it under settings on the watch (Versa). I've set the watch to sleep between 9pm and 9am. Hopefully this is not the same as "target sleep schedule" because that's not my target sleep schedule, only the time period I don't want the Versa to wake up on its own.
Best Answer11-29-2020 19:14
11-29-2020 19:14
That's what Sleep Mode is for. You can find it under Settings. You can schedule it for certain hours automatically.
Best Answer11-30-2020 01:19
11-30-2020 01:19
I cannot find this setting. Can you give instructions on which settings page to find this?
Best Answer11-30-2020 01:38
11-30-2020 01:38
