12-11-2021
17:50
20:40
12-11-2021
17:50
20:40
Change Celsius to Fahrenheit,
text message responding- doesn’t work - can’t get Alexa or google assistant to work - point me in the right direction
thanks
HI @Reikerox - see How to change Temperature - for Weather, Centigrade - Fahrenheit, Versa 3
Also the general temperature setting for the Fitbit App can be changed by clicking on the profile photo, App settings, units, temperature.
Hi there, @Reikerox. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
I've seen that you contacted our Support Team and they've already addressed your issues. If you still need help, please feel free to contact them back so they can continue assisting you.
Have a good day.
Best AnswerI'm having the same problem with my Versa 3 and I have been had it very long I had somebody from the Fitbit app department help me change it back from centigrade to fahrenheit and it was reading the correct temperature it's somehow on its own change back to centigrade how does that work and how do I get that to stay like it's supposed to Fahrenheit is the right temperature I didn't touch it it changed on its own what's wrong with this
Same problem with mine for 2 years now.
Hi @JRJacobson - could you indicate what problem you have and whether you tried the suggestions in this topic to resolve it.
Thanks @JRJacobson - in the article posted earlier it shows the multiple places where temperature has to be modified.
Have you checked all three possible places. If you are seeing weather IN a clock face may be change to another clock face if you can't find a setting for it.
Thanks @JRJacobson - did you remove all cities from the weather app, in the Gallery, and set the temperature there and then sync.
If necessary logout of the Fitbit App and swipe off the active window and in Android clear the storage cache and force stop it and restart the phone and watch and sync.
@JRJacobson- sounds like you have tried it all, do you have multiple devices with the Fitbit App installed? Also after reinstalling you will need to go to the Gallery tile, weather app settings again.
Clues as to your country and phone type would help.
You should be able to get the weather in either C or F, it should be resolvable.
