03-08-2019 18:31
03-08-2019 18:31
Hi everyone,
I have had my Versa since August and it has been functioning well until a few weeks ago. It is collecting all data and reporting it properly to the app. But, it won't read my hours slept, water intake, and days exercised. It reports it to the app, and the app shows my updated, daily data, but it won't read on the watch. It's showing the data from about three weeks ago for those three stats. I can't figure out how to get it to work. My Versa also won't receive texts anymore. It did and just suddenly stopped. I can't figure it out. Does anyone have any suggestions?
Thanks!
03-08-2019 18:35
03-08-2019 18:35
Hi @pmfawcett Have you tried restarting your Versa several times? If not, give it a go and report back.
Helen | Western Australia
03-08-2019 20:05
03-08-2019 20:05
Hi Nelly,
Thank you! I turned it off three times and synced it to the app and it's still not working. 😞
Tricia
Best Answer03-08-2019 20:33
03-08-2019 20:33
Do you have any other way of syncing? Another device?
Just wondering what is the source of the problem. Sometimes the app or phone connection is not connected right.
If you have already tried restarting your device at least three times, please try one or all of these options below:
-restart your phone
-restart your Bluetooth connection by “forgetting the device” and reconnect.
-uninstall and re-install the app
-removing and re-installing your device on the app
let us know if any of these helped.
Best Answer03-09-2019 12:57
03-09-2019 12:57
Disconnecting the Bluetooth and uninstalling/reinstalling the app worked!
Thank you for your help!
