06-17-2018 04:32
06-17-2018 04:32
Hi, so I've had my versa for almost two months now and it has been working great and I have loved the watch alot! But recently it just stopped syncing and will not connect to my phone via Bluetooth and I get no notifications as well. I have an Android phone and I did update to Android Oreo about a week and a half ago. My versa worked fine though and then all of a sudden 4 days ago it stopped syncing and disconnected from my phone. Could this be an issue with me updating my phone's software? I have tried updating the Fitbit app and such and that didn't work...dont know what other fixes I could try. Is anyone thats an Android user having problems?
Best Answer06-19-2018 05:25
06-19-2018 05:25
Thank you! I did a live chat with Fitbit support on Sunday and basically followed those same steps. Mine is working right now too! Just crossing my fingers it continues.
Best Answer06-17-2018 05:22
06-17-2018 05:22
What phone are you using? Is it on the Supported Devices List? It sounds a bit as if that may be the problem to me.
Helen | Western Australia
Best Answer06-17-2018 05:25
06-17-2018 05:25
A Samsung Galaxy sS7 edge I checked and it's on the supported device list...sigh..;
06-17-2018 06:25
06-17-2018 06:25
Update: I have tried upairing my versa and trying to set it up again and I'm getting the message that the Bluetooth isn't working. But my phone finds it intially. I have tried uninstalling the app as well and reinstalling it and that didn't work either...
06-17-2018 06:28
06-17-2018 06:28
I have the same phone with Oreo software as well and am having the exact same issue. I would love to hear the what the Fitbit community service rep has to say about this. I have had several different Fitbits in my time and was excited about the Versa but I am getting less excited now that it doesn't sync properly and no longer gives me notifications consistently. Come on Fitbit, you can be better than this!
06-17-2018 06:28
06-17-2018 06:28
06-17-2018 06:32
06-17-2018 06:32
Yepp, same here I was so excited about the Versa as well! Now I am just frustrated with it..
06-19-2018 05:22
06-19-2018 05:22
Update: my Versa is working again!!! Whoo!! Fitbit emailed me and gave me some troubleshooting steps and they worked like a charm:) firstly turn go to your Bluetooth settings and choose to forget your versa and then force stop the Fitbit app and then restart your phone and turn off your watch and then turn your watch back on once your phone has restarted and set up your versa in the app again( it's a fast setup since the update doesn't have to be downloaded) anyway hope this helps!! 🙂
06-19-2018 05:25
06-19-2018 05:25
Best Answer06-26-2018 20:57
06-26-2018 20:57
I'm having the same issues! It's so frustrating!!
06-27-2018 02:02
06-27-2018 02:02
Thanks for that. My versa stopped syncing on Friday. I have an S7 edge. Your resolution worked for me. Appreciate it. If this was an issue, like it looks like it was, maybe Fitbit should have posted something rather than wait for a whole lot f people to complain
Thanks again 🙂
Sue
Best Answer08-30-2018 05:22
08-30-2018 05:22
How do you turn your watch off and on?
Best Answer10-04-2018 09:12
10-04-2018 09:12
On your watch go to Settings > About > Shutdown.
Best Answer10-28-2018 10:36
10-28-2018 10:36
This worked for me thank you so much!
Best Answer10-30-2018 09:49
10-30-2018 09:49
what is the solution? I have the same issue getting the notification on my versa watch and also synchronizing it
Best Answer11-16-2018 16:25
11-16-2018 16:25
And we Versa owners should not have to do this daily to get our trackers to sync! This is my 3rd and last FITBIT I will get.. Too **ahem** frustrating.. Only syncs when I spend an hour dicking around with it.
05-27-2019 06:29
05-27-2019 06:29
Love my Versa, but all of a sudden it stopped syncing to my IPhone 7+. Can you help me resolve this issue?
