08-16-2022
20:33
17:25
08-16-2022
20:33
17:25
I used to get 5-6 days between charges on my Versa3. Since the most recent update I am lucky if I get a day and a half.
I had made zero changes in the settings or in my normal usage. The only change that was made was the update, so that has to be what is causing the problem.
I have not changed any settings.
I was charging the battery every 3-4 days but in the last two days a full charge is now only lasting about 8 hours.
Best AnswerI updated and have had no issues in 5 days. I will say restart the watch.a proper hard reset where you hold the side button till it resets. Otherwise do a factory reset. In general I haven't noticed anything major with the update granted I had no issues to start with. Updating is always the roll of the dice.
I have had this watch for just under 2 yes.one tip I can give is in any update keep the watch and phone next to the WiFi router then do a hard restart
Best AnswerYou are one of the lucky few. I did do a reboot. It’s one of the first things I do when electronics start acting up; it clears the RAM which is often what’s needed. But this is clearly an update issue and Fitbit is aware of it and working on a new update. At least that is what the customer service person I spoke said. She said the last update caused issues with multiple Fitbit products.
Best AnswerThis is why as a practice I've kept my automatic updates for Fitbit turned off. I typically will give an update about a week and then check to see if they're reported issues with it before I manually start the update. I screwed up yesterday and let the app update and I'm sitting here in the same boat with all of you all. My Fitbit started the night last night at about 80% charge and I woke up to 5% remaining battery. I charged it back up after restarting it to 99% and 5 hours later it's already dropped to 61%. This will probably be the last Fitbit I purchase. I shouldn't have to babysit updates to make sure they're not going to break my device!
