08-15-2022
10:36
17:28
08-15-2022
10:36
17:28
Earlier today my watch was at 98% charge and perfectly normal. Then a few hours later I lifted my wrist to check the time and it was completely dead. The screen is black. The button does not respond to anything. There was a vibration but now nothing. It won’t charge. It’s just completely unresponsive. This watch is less than 6 months old! Help.
08-15-2022 12:15
08-15-2022 12:15
Same thing just happened to me today. Mine is less than 6 months old as well. Any suggestions and help will be greatly appreciated.
08-15-2022 12:17
08-15-2022 12:17
The same thing happened to me as well today. Never had any issues before today. Mine is less than 6 months old as well. Any help or suggestions to fix this issue will be greatly appreciated.
08-15-2022
20:06
10:53
08-15-2022
20:06
10:53
Hi all, this can happen if the watch got wet, it may even get hot when changing and if so stop immediately. It confirms internal damage.
In case it simply needs charging follow the instructions in this article How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
If it's not a charging problem chat with support as described.
If the watch is found faulty the quickest resolution is to take it back where you bought it for replacement, hopefully over the counter.
