06-04-2019 20:19
06-04-2019 20:19
Last weekend my versa blinked randomly and would vibrate, did this until I reset it. It worked all week without issues. This weekend, the left side button stopped working. The left button is not clogged or dirty, it does still press easily. I can get to my home screen buy clicking the bottom right button. How can this be fixed?
06-04-2019 20:22
06-04-2019 20:22
Welcome to the forums!
I know you said its not dirty but this still might help
Hope to see you around the forums!
Wendy | CA | Moto G6 Android
06-05-2019 07:56
06-05-2019 07:56
@Mamapatchrn welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since the left button is not working even though you noticed that it's not dirty.
I'd just like to to know if the issue persists or if it got resolved after following the advice that shared @WendyB.
In addition, it may sound weird but are you using a third party clock face? If so, try changing the clock face to one developed by Fitbit. After this, try the button and see if it works.
Keep @WendyB and me posted on the outcome! ![]()
06-06-2019 05:34
06-06-2019 05:34
Thank you for your feedback.
I did clean the contacts with compressed air in the can you use to clean computer keyboards. This did not resolve the issue.
I have the Fitbitmoji clock face. I have had theis face for almost 2 months now. I added it in April.
Welcoming more ideas. Thank you
Best Answer06-10-2019 08:03
06-10-2019 08:03
@Mamapatchrn thank you for getting back and trying the troubleshooting steps recommended above. Since the issue persists, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any questions! ![]()
Best Answer06-10-2019 09:50
06-10-2019 09:50
Hi I’m having the same problem. Did you get yours resolved?
Best Answer06-11-2019 10:24
06-11-2019 10:24
@Lilminx82 thank you for joining us in this thread and our Fitbit Community! Since your Versa is also experiencing difficulties with the button, I'd like you to try cleaning the button in order to remove dust around the button using a toothpick.
In addition, I'd like to know if your Versa turns on when you plug it in the charger.
Looking forward to your response! ![]()
Best Answer06-11-2019 11:48
06-11-2019 11:48
Hi I have try cleaning resetting and resorting nothing seem too work. But it does turn on when charging. 🙂
Best Answer06-12-2019 10:19
06-12-2019 10:19
@Lilminx82 thank you for getting back and trying the workaround shared above. Since the issue persists, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Best Answer07-01-2019 08:31
07-01-2019 08:31
I had the exact problem my versa is only a year old and has been gently used. Last week screen started jumping around erratically and so I had to shut it down now just a few days ago the left button no longer functions. Now I have no ability to control the music playing on my iPhone while running. This is very frustrating.
Best Answer07-02-2019 11:51
07-02-2019 11:51
@Kinmada thank you for participating in our Fitbit Community! Since the left button is still unable to work, please try using a toothpick around the button in order to remove any dust that may affect the functionality of the button and see if the display turns on after pressing the button.
Let me know how it goes! ![]()
12:33
09:42
JuanJoFitbit
07-02-2019
12:33
09:42
JuanJoFitbit
Thanks. I did try this and no change. I contacted FirBit and they told me since I purchased it jumper than 365 says ago they can’t replace it.
(Sent from iPhone)
Moderator edit: removed personal info
Best Answer07-03-2019 09:41
07-03-2019 09:41
@Kinmada I'm sorry to hear that a replacement couldn't be provided since your Versa is not longer under warranty.
I totally understand how you feel about this and I appreciate your feedback and comments since this helps us to keep improving.
