03-05-2022 00:43
03-05-2022 00:43
How long is the life span of the Versa 2? I've had my since 2019 and I am starting to experience trouble now with my versa. It won't sync with my phone, and it won't conect to wifi. Except those issues, I love my watch and I don't wan't to switch it out.
03-05-2022
02:33
07:05
03-05-2022
02:33
07:05
Hi @Skepparn - the problems you are experiencing may be other issues and not the watch.
Versions of firmware and Application software get regular updates and there may be things not working the same way as before, or as well as before, so make sure that it is a watch issue before parting with it.
You might find something here Why won't my Fitbit device sync?
Best Answer03-05-2022 16:48 - edited 03-05-2022 17:41
Hi @Skepparn, do you have the fitbit app loaded on multiple devices? If so, log out of fitbit on the other devices so you are only logged into fitbit on one device. Versa can get confused if it has multiple devices it can sync to. I had fitbit app on iPad and my phone and discovered logging out of iPad instantly cured same issue you are experiencing
