09-24-2019
02:18
06:58
09-24-2019
02:18
06:58
I want to see my current live race pace on a run on a Fitbit Versa 2 with connected GPS. Is this possible?
09-26-2019
08:40
12:17
09-26-2019
08:40
12:17
@regnavetto You can absolutely see your live pace on the screen as you run. You do this by using the Customize Stats option on the Versa 2 itself. Go to your Exercise app on the Versa 2 > Run > tap the gear icon > Customize Stats. This part of the menu lets you set a top stat, a bottom stat, and the ones you scroll through in the middle stat. If you don't mind seeing your pace in the smaller font, then set Pace as the top or the bottom stat. For example, my top stat is distance and my bottom stat is elapsed time. If you want your pace to be the middle stat -- and no other choices -- tap on the Middle Stat and uncheck everything but Pace. If you want to keep other metrics, you can. If you keep other options, then you will need to scroll the middle stat once you start your run to have pace on the screen.
Does this help?
Laurie | Maryland
Hello there @regnavetto, it's nice to see you around the Community Forums.
Use the Exercise app to capture real-time stats, including heart-rate data, calories burned, and elapsed time, for specific workouts. Pause the workout if you take a short break and review the workout summary when you’re done.
If you used GPS to track your workout, a map of your route, pace, and elevation are stored in your exercise history. For more information on GPS, see How do I use GPS on my Fitbit device?
I've moved your post to Versa watches as there are more chances to get related replies here.
08:40
12:17
09-26-2019
08:40
12:17
Does this help?
Laurie | Maryland
