04-03-2020
13:33
08:49
AlvaroFitbit
04-03-2020
13:33
08:49
AlvaroFitbit
If I forgot to start my watch before a workout, I used to be able to go to the dashboard and select a block of time and it will calculate it for me. Now it asks for a start time, duration AND calories!? How the heck am I supposed to do that. I'm guess y'all "fixed" something with the latest update? Please put it back the way it was...or at least give us the option to select either "Duration" or "End Time" so that we can find out how many calories we burned. Why would you have to enter calories anyway with either selection? The watch should be able to easily calculate it. Thanks for your consideration.
@TheTank67 Thanks for stopping by! Sorry for the delay in my reply.
Let me help you with manually logging your activity. The calories are optional when you log your activity so you can save it without this information and Fitbit will calculate them for you. You can also try logging them using the website at Fitbit.com. If you get any error message could you share a screenshot of it?
Let me know how it goes.
