04-09-2020 11:16
04-09-2020 11:16
I have motion screen wake (auto) on, but my Versa 2 will NOT wake up when I move my wrist! I have selected this setting on the quick setting from the drop down menu, and I’ve also selected it in the settings app. It will only wake up when I click the button! It won’t wake up by tapping or moving my wrist.
I only bought it today so it couldn’t be damaged. I’ve tried powering it off but no luck. Can someone please share any tips?
thanks!!
04-09-2020 11:48
04-09-2020 11:48
Emma, swipe left to Settings and scroll down and make sure Sleep Mode and Do Not Disturb are turned Off.
04-09-2020 12:33
04-09-2020 12:33
Yes I have tried that, and it still does not work. Thanks
04-09-2020 13:19
04-09-2020 13:19
Try a Restart and do it several times if necessary.
10-03-2020 03:25
10-03-2020 03:25
This worked perfectly. Thank you.
Remember to check that BOTH options are off in Sleep Mode and Do Not Disturb mode.
Thank you again
