I don’t see motivational/inspiring messages in the today app anymore. I’ve tried settings at the bottom of the today app and Inpiration is not an option I can select. Have motivational messages been removed indefinitely? I’m using a Versa.
Hi, do you mean the hourly notification to move? If yes, then go to the Fitbit app and to my Apps and see if the Today screen needs to be updated. If yes, update it, restart your phone and your Versa and it should be back. Also make sure that you have the latest version of the Fitbit app on your phone.
Best AnswerI am having the exact same problem. I miss those messages and I don't ever remember dismissing them or disabling the notifications. Have you figured it out? I still see below content as part of their set up so I'm unsure why I can't see them when I swipe up.
"Today feed is accessed via a swipe up on the clock face. Randomly the top of this view will have tips to help motivate you or explain the features of the watch"
Best AnswerThanks Kuzibri but I’m talking about the motivational messages and tips that used to be listed at the top of the today app when you swipe up.
Seems there was an option at one point to turn it on and off but now it’s just gone.
Vikiya09 unfortunately no not yet. I’m hoping someone will know the answer. I know there was an option to turn it off in settings when you swipe up but it’s not there anymore.
Best AnswerHi, when I swipe up form the bottom of the home screen to see the Today screen, the first that is shown are steps and the second one is HR. the rest I have disabled, but enabling it, the first I see are activities. Do you mean that?? After activities, I see, in this order: steps per hour - Exercise - Sleep - Water - Food - Weight - and Badges.
Best AnswerYes. In the past, at the top of your today page there would be motivational messages then your steps etc.
I did see in other discussion in the community here, they were able to disable it by pushing settings at the bottom of the today page and disabling it but that isn’t an option anymore. I’m wondering if Fitbit removed motovational messages all together in the latest update? If so, it should probably be removed from the description of the app. See below.
Best AnswerHi see this topic about certain notifications: https://community.fitbit.com/t5/Android-App/Update-6-26-2018-In-app-Notifications-no-longer-in-Notif.... And that's before the update was released. Hope this helps!!
P.S. press the account icon in the dashboard of you Fitbit app and scroll down to notifications and press that. You will see the page of push notifications and choose the one you need. I think that should be challenges. Good luck!!!
Best Answer@MonaBear @Vickya09 I am going to flag your question to get moderator attention. I remember seeing the motivational messages. I thought I disabled them. I cannot find any setting to turn them on. Page 17 of the Versa Manual shows an example.
I found another thread where someone noticed they disappeared back in Dec 2018.
I would like an answer to this.
Laurie | Maryland
Best AnswerI wish I could turn OFF those annoying messages at the top of my app but can’t find the option!
