12-02-2018 18:38
12-02-2018 18:38
I know a lot of people have had trouble with the Versa's music control system. Mine actually works pretty well for controlling both podcasts using Podkicker Pro and streaming music through Google Music on my LG G7. Pause, track control, and volume all work well.
The only thing that doesn't work well is the track listing (the song currently playing on the phone). It never updates from the first track that started playing unless I do the following:
Now the correct track name appears.
But the track won't change at all until I repeat above.
Is this a bug that will be fixed? Or is there something I can do now to fix it? It's pretty annoying to never know what track's actually playing without going through all of the above or taking out my phone and looking at it.
12-03-2018 03:15
12-03-2018 03:15
@SunsetRunner Welcome to the Fitbit Community! It's great to have you here! Sorry to hear that your Versa isn't updating the song name. Try refreshing the connection between the Versa and your phone by going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
Best Answer12-03-2018 16:21 - edited 12-03-2018 16:21
@AlvaroFitbit - Thanks. Tried everything you said to a T, but it didn't work -- the problem remains exactly as before.
One thing I forgot to mention is that the track progress bar proceeds as normal for a little bit, then flashes between the actual track position at the end, then when the track ends, stays at the end while the next track plays. Don't know if this'll be helpful for troubleshooting.
Best Answer12-15-2018 21:58
12-15-2018 21:58
Strangely, looks like it's working just fine now on my LG G7. I didn't do anything to fix it. Just seems to be working now!
Best Answer12-17-2018 10:40
12-17-2018 10:40
@SunsetRunner It's great to see you in our Fitbit Community! It's great to know that your Versa is working properly now. Thank you for posting the update here.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! ![]()
Best Answer01-18-2019 18:56
01-18-2019 18:56
Unfortunately, it looks like the solution was temporary. The same problem has reoccurred, just as randomly as it started.
