12-24-2018
11:31
16:56
EdsonFitbit
12-24-2018
11:31
16:56
EdsonFitbit
Every week or two another stupid error with my Versa. Today it won't sync, just looking,
Yes, I did a hard reboot to my IPhone, Yes I restarted Versa.
Frankly I'm so fed up with this useless watch I'm ready to toss it the garbage
Moderator edit: added label
12-24-2018 12:33
12-24-2018 12:33
I’m alao having the same problem. Not immediately after doing the update, just started today. Have rebooted, logged out etc and still no joy
Best Answer12-24-2018 15:37
12-24-2018 15:37
Hi, i really understand that this is frustrating like hell. Did you update to the latest Firmware Version of Fitbit? If you have not yet, go to your Fitbit app and see whether the Versa is still there. If yes, delete it, restart your phone (BTW, do you have the latest Fitbit app?) and also reboot your Versa. If you do not have the latest Fitbit version, delete it from your phone , restart it and reinstall Fitbit app again. Open the app, put your Versa in the charger, connect it to your PC and make sure that in the settings of your Versa BT is on. Start the Fitbit app on your device, with BT enabled, and press "add device" and redo the entire procedure. Hope this helps, good luck and Happy Holidays.
Best Answer12-26-2018 04:55
12-26-2018 04:55
