05-20-2019 14:35
05-20-2019 14:35
My tracker is no longer connecting to the app. I tried all the possible options. Re installed the app; restart versa' restarted the phone and bluetooth, it syncs for a minutes but never connect 😞
05-20-2019 15:15
05-20-2019 15:15
@Nawaraa I asked if you could receive the notifications on your Versa because it means there's no issue with the connectivity. By not staying connected do you mean that when you open the app, Versa says connected for a while showing live stats like heart rate and then 'disconnects'? If yes, then that's normal. If you receive the notifications and can sync, then it's ok. Just make sure All-day sync and Always Connected are enabled in the Fitbit mobile app, and that Fitbit mobile app is not being optimized by Android itself in the Battery Settings.
05-20-2019 14:41
05-20-2019 14:41
@Nawaraa Are you able to receive notifications? Does it sync throughout the day or when you open the fitbit mobile app? When was the last sync (open fitbit app, tap on Versa and scroll down to the Sync section)? Finally, what phone model and OS do you have and which version of Fitbit mobile app are you running?
05-20-2019 14:47
05-20-2019 14:47
Best Answer05-20-2019 15:15
05-20-2019 15:15
05-20-2019 15:29
05-20-2019 15:29
Best Answer05-20-2019 16:06
05-20-2019 16:06
@Nawaraa You're welcome! 😄
05-23-2019 12:05
05-23-2019 12:05
@Nawaraa Welcome to our Fitbit Community! I'm so glad to hear that the information that shared @Marrrmaduke was helpful.
In addition, I'd like to share this help article which contains troubleshooting steps for syncing issues for future references.
Let me know if you have any questions! ![]()
