05-17-2018 13:13
05-17-2018 13:13
I just got my versa a few days ago and the watch face will not turn on when I flip my wrist. I have to hit the button on the left to see the time. How can I fix this? I don't seem a setting for this.
05-17-2018 13:18
05-17-2018 13:18
Is your quick view on?
05-17-2018 13:22
05-17-2018 13:22
How do I check? I feel like my versa is VERY basic and doesn't give me options like the videos I've watched on YouTube
05-17-2018 14:09
05-17-2018 14:09
Open your Fitbit app, tap on your versa and scroll down to “quick view” and see if it’s on.
05-18-2018 03:09
05-18-2018
07:24
18:56
DavideFitbit
05-18-2018
07:24
18:56
DavideFitbit
Long press/hold the main button on the right of the watch. After it vibrates there should be a menu with the option for screen awake. Set this to auto and it should wake with a flick of the wrist.
*Sorry should be left side of the watch
Moderator edit: merged replies
05-20-2018 03:57
05-20-2018 03:57
Yes sir it's on and has been.
11-02-2018 08:01
11-02-2018 08:01
This worked thanks!!
11-11-2018 17:41
11-11-2018 17:41
Thanks so much! It worked ❤️
12-29-2018 21:53
12-29-2018 21:53
Thank you so much! It worked!!
01-03-2019 22:54
01-03-2019 22:54
Thankyou 🙂 worked for me 😉
01-10-2019 15:54
01-10-2019 15:54
Thank you!!!
01-21-2019 13:34
01-21-2019 13:34
Thanks! I appreciate it.
01-21-2019 13:36
01-21-2019 13:36
Thank you! I would never have found it out on my own.
02-04-2019 22:06
02-04-2019 22:06
Okay if it’s on . I suggest you switch it off , then back on , thank click on ( sync now)
02-14-2019 03:01
02-14-2019 03:01
That worked for me, thanks for the tip.
02-16-2019 08:12
02-16-2019 08:12
Thank you! I don't know how mine got turned off, but it did. This helped!
02-28-2019 12:36
02-28-2019 12:36
Yes. I tried both buttons on the right, and I'm like which is the main one? They didn't do anything. So, I tried the left one, and it worked. Thanks.
03-05-2019 07:13
03-05-2019 07:13
Its work. Tq sir. 👍
03-09-2019 16:22
03-09-2019 16:22
@Andybbb wrote:Long press/hold the main button on the right of the watch. After it vibrates there should be a menu with the option for screen awake. Set this to auto and it should wake with a flick of the wrist.
Thanks! It worked perfectly!
