09-15-2019 09:38
09-15-2019 09:38
Using Android, I go into the music control screen on my Versa, go to Bluetooth on my phone but Classic Never show up, in fact Versa doesn't even show up. Using a Huawei P20 Pro BTW which is on the list.
Best Answer09-15-2019 10:34
09-15-2019 10:34
Swipe over to settings. Tap and swipe up to bluetooth.
Now tap to change Bluetooth to pair.
Now open the phones Bluetooth and connect the Versa classic.
09-15-2019 10:41
09-15-2019 10:41
Yeah Versa classic doesn't show just Versa
Best Answer09-15-2019 12:14 - edited 09-15-2019 14:56
Did you change the Bluetooth setting to pair?
Could the versa already be connected to a different phone?
I needed to press scan on the phones Bluetooth.
09-15-2019 12:20
09-15-2019 12:20
Best Answer09-15-2019 12:28
09-15-2019 12:28
That is your music control screen.
On the Versa you need to swipe left to get to settings, tap, swipe up to go to Bluetooth.
Now put the Versa Bluetooth into pair.
ok i have the Versa 2 and i think the following may be different in your Versa. But you need to have it say Pair. This is the screen to turn on Versa Classic.
09-15-2019 12:41
09-15-2019 12:41
Best Answer09-15-2019 15:00
09-15-2019 15:00
You are still going to the music control k instead of the Bluetooth settings.
First mistake i see is that the side button is being held in.
Turn on the display and swipe left. Not hold in button.
Bluetooth needs to be turned on and set to pair.
09-16-2019 11:34
09-16-2019 11:34
Did you get it working @dave_in_ni
09-16-2019 11:53
09-16-2019 11:53
Best Answer09-17-2019 09:18
09-17-2019 09:18
Does the Versa Bluetooth say Pair on the fitbit?
Have you tried restarting the phone and Fitbit? Better yet, shut both off?
