11-27-2018
23:29
05:18
AlvaroFitbit
11-27-2018
23:29
05:18
AlvaroFitbit
Seeing as this tracker uses pins can you use any old watch band?
11-28-2018
05:08
05:18
AlvaroFitbit
11-28-2018
05:08
05:18
AlvaroFitbit
I dont think so, though there might be some you can get to fit. The part ofnthe watchbthatvthe band and pin fit into is a particular shape and I am not sure a normal watch band would work. You could always try though!
Helen | Western Australia
11-28-2018
05:08
05:18
AlvaroFitbit
11-28-2018
05:08
05:18
AlvaroFitbit
11-28-2018 05:17 - edited 11-28-2018 05:18
@Hibrn8 Welcome! It's great to see you around! Thank you for your inquiry. As @NellyG they may not be compatible with the Versa. Still if the band is thin and the pin is the same length you could try attaching it to your Versa. If you are successful could you share some pictures? This may help other members with the same question.
I look forward to your reply!
12-05-2018 04:26
12-05-2018 04:26
Hi AlvaroFitbit and thanks for the reply. I don't actually have a fitbit Versa as yet which is why I thought I'd better ask the question first 😛
cheers,
Forest
