11-01-2019 02:00
11-01-2019 02:00
Hi, both my husband and I have a Versa and ionic Fitbits and are unable to receive WhatsApp notifications. The Versa and Ionic are at Version levels 68.9.15. Can anyone offer advice on how to resolve the issue as we both received notifications in the past.
11-01-2019 02:54 - edited 11-01-2019 02:57
sorry, double post. Please see below.
11-01-2019 02:56
11-01-2019 02:56
Hi, @agh55 , what phone are you and your husband using? If you are using iPhones updated to iOS 13 you may be being affected by a known issue with notifications. Fitbit is working on a fix for this.
If it isn’t that, sometimes when the app is automatically updated it goes back to default settings, so it is worth checking that WhatsApp notifications is still turned on. On your app on the phone, go to the Account screen (that’s your picture, in the little circle top left). On the Versa screen find notifications and make sure that you WhatsApp is checked (ticked). I find it works best to choose WhatsApp messages as my primary text message notification. You can add SMS messages in under “App notifications”.
The instructions are the same for the Ionic.
Also, do you sync with more than one device? For example, I use an iPad to sync as well as my phone and they can interfere with each other if Bluetooth is turned on. Because of this, I almost never get messages when I am home, but only when I am out of range of my iPad.
11-01-2019 03:40
11-01-2019 03:40
Same problem.. Im using android and not receiving WhatsApp notifications. Done several troubleshooting such as install uninstall app etc. Pls help what should i do
11-01-2019 04:00
11-01-2019 04:00
Hi, @Kimy507 , have you tried the steps I suggested above?
Go to the notifications section of your app and make sure WhatsApp notifications are turned on. I find it works best if you set WhatsApp as your primary message, and add SMS messages under App notifications.
11-01-2019 05:39
11-01-2019 05:39
Hi Julia, yes i have tried it but still not receive any notification from WhatsApp. Any suggestions for this issue?
11-01-2019 06:47
11-01-2019 06:47
@Kimy507 , are you receiving other notifications (calls/ SMS text messages)? Have you set WhatsApp as your primary Text Message notification?
11-02-2019 03:14
11-02-2019 03:14
