02-11-2019 14:12
02-11-2019 14:12
My husband and I just bought Fitbit Versa. And it’s not tracking his sleep, and the heart rate works when it wants ? These things are brand new !!! What’s going on ? Tried reboot and reset, nothing improved. I still have my Fitbit HR and it works perfectly fine and it’s way older.
Best Answer02-11-2019 14:30
02-11-2019 14:30
Hi, in order to log Sleep correctly, it will need to have an accurate HR reading, especially the resting HR during sleep. When HR monitoring is not working well, Sleep is also not logged. You have tried already a restart and a reset. After that last one, did you setup the Versa again to your phone's Fitbit app? This is necessary as the Versa is acting like a new watch after a reset. Try to set it up again with your phone and if it's asking "there is already a Versa present, should it be replaced, press simply yes and continue the process as usual.
Best Answer02-11-2019 15:16
02-11-2019 15:16
Best Answer02-11-2019 15:22
02-11-2019 15:22
You're welcome!!
Best Answer02-11-2019 16:09
02-11-2019 16:09
Best Answer02-11-2019 16:27
02-11-2019 16:27
