03-10-2020 14:54
03-10-2020 14:54
I face notification issue for calls its no notnot work all time for text & whats app it's not working and I face this message
Notification system not runnig a phone restart is required to re-enable notification on your tracker and i restart the phone and vesra with no luck
03-10-2020 14:56
03-10-2020 14:56
Notification system not runnig a phone restart is required to re-enable notification on your tracker and i restart the phone and vesra with no luck my mobile is xaomi note 7
Best Answer03-10-2020 15:19
03-10-2020 15:19
I don't it on the list of compatible devices? click to see
Best Answer03-11-2020 07:32
03-11-2020 07:32
How i request to add xaomi note 7 in the list to receice notification calls and text message
Best Answer03-11-2020 07:59
03-11-2020 07:59
You can suggest it be added, but there are literally thousands of Android phones that are out there. Each manufacturer makes several versions of the same phone, so it's hard to know when any one phone would be tested and added.
